Help get this topic noticed by sharing it on
Twitter,
Facebook, or email.
Twitter,
Facebook, or email.
idj3 not working....at all,
I have a small problem with the idj3 controller that I recently purchased It only lights up and has one other working functionality which is playing my iPod. It currently has no DJing functions and is just a paperweight. I tried to place the new firmware on the unit but to no avail. I installed everything 3xs and still have the only lighting up function. Only when I press the 2 sync buttons simultaneously I get the effect of most of the lights turning off and the sync to stutter buttons on both decks on and the first autoloop button on the left deck on. The DJ program recognizes it but any movement on the unit does not effect the program. Please help
yer i having the same problem and need some help to work this out iv tryed every thing all lit up but controller wont work would really like some help
- view 2 more comments
What operating system do you need the driver for?
similar problem here, my Windows 7 system sees the audio driver and the controller lights up but it doesn't function all the lights are just on and nothing else happens
Just got my iDJ3. I had that problem as well. I bought mine off eBay. I ended going to Numark's site on the Products tab, go to the Docs and Downloads tab. There is a driver for the iDJ3 for different operating systems. Find the one that matches your setup, download that driver and try it again. It worked for me (except for the crossfader being backwards LOL)/
I responded to your other thread.
Loading Profile...
EMPLOYEE
