IDJ3 Not working at all.
When plugged into computer, only the cue buttons and the keylock buttons are lit up. The IDJ3 doesnt work when I plug it into virtual dj. There is no response. Only the master volume works.
I just purchased this, any help? I am using a PC windows 7
Official
Response
http://dl.dropbox.com/u/49840836/Driv...
(Win 32bit)
(Win 64bit)
(Mac)
Hello, please can you advise your computers specification?
Sony Vaio
Processor: Intel Core i7 CPU Q740
RAM: 6.00 GB
System Type: 64 Bit -
Hello it seems that you may have accidentally erased your Firmware on the iDJ3 can you advise if you tried to update it. Our friendly support team are available to help over the phone in real time on 401 658 3131. We are available 8:30 to 7:30 ET.
- view 1 more comment
i get a "unidentified external error" Message
Make sure to download the iDJ3 driver before connection. It can be found here under (documents & downloads):
http://www.numark.com/idj3a -
What a crappy way to update firmware... Everyone is stuck it seems.....Numark needs to give a solid solution and not wait untill people find out themselves...
I'm stuck too, and no solution yet.
Numark, please solve this problem and give us a beter "how to" guide!!! -
I am trying to install and set up but system keeps timing out when I connect DJ via USB.
I am using a Dell I6400 with Windows XP 2002 SP3, 32 Bit, Intel CPU 1.66GHz
Installed drivers as instructed. After drivers system asks to be connected via USB and then times out. -
http://www.numark.com/idj3a (neccesary drivers found here)
Make sure that the device is being recognized as a USB port before trying to run the update. If you are not sure your device is correctly recognized or to check for errors look in your control panel through your system preferences. There you will find your device manager and a (audio,video, game controller list). Make sure that the IDJ3 is showing up on this usb list when you plug it in. The list will refresh showing you a new item. If your list does not refresh then try another usb port. There may be USB conflict we need to solve before the update can be considered so make sure there are no error messages attached to the new device. -
I am having somewhat the same problem. All the lights are lit up like it's working, but whenever I launch a mixing program, Virtual DJ, or Traktor, It says there's no external device connected.
The computer recognizes the device, but it says there are no drivers for it. I saw your post above with the drivers, J Sandeen, But it appears that it goes to a 404.
All help is appreciated, I'd like to get started. :)- view 3 more comments
You bet!
Hey. Me again. I recently had to upgrade my Operating System to Windows 7 Ultimate 64Bit. Would it be possible to send me the link for that as well?
Thanks! -
(Win 32bit)
(Win 64bit)
(Mac) -
Do any of you still have this problem? I just spent 10 hours straight working on it for my brother. I know the fix like the back of my hand. Let me know!
I could use some help with a walkthrough, E-mail me what you think should help my situation. djamazon@gmail.com
I could use help from you to jimabanek@hotmail.com
Still having the issue...also trying to get installed with Windows 7...help is appreciated. aidenarchangel@gmail.com
I could use some help as well. I fire up VDJ home edition and I cant configure the device properly.
This device should work with Torq correct?
If you could please e-mail me your walk through at djamazon@gmail.com
Best regards -
For anyone needing help getting iDJ3 to work on their computer and are running into troubles I have a solution. Please e-mail me personally if you are in need of assistance. Include what the current state is when plugging in the device to the computer (what lights come on), what operating system you use and what program you're trying to get it to run with. I have only only verified my cure by using Virtual DJ PRO, and Windows 7. My cure will NOT work on Windows XP, I have tested it with both XP and 7, I have not tested it with Windows Vista or MAC. If you can at least borrow a PC with Windows 7 on it to get it SET UP, afterwords it WILL work on Windows XP with Virtual DJ PRO.
i3arbieBrii@gmail.com
I'm here to help! -
J Sandeen,
I downloaded the drivers you had links for on this page. When I went to install everything was fine then I got the message, "Unfortunately the installation failed. (Error: timeout - 0x0005)" I have tried several times. Same message.
My IDJ3 still doesn't work. Now what? -
Loading Profile...
Twitter,
Facebook, or email.
EMPLOYEE
EMPLOYEE
