N4 with Virtual DJ
Can someone tell me how I set up Numark N4 with Virtual DJ? When I used the mixtrack pro it was just to plug it in, but with the N4 it ́s not working..
Official
Response
EMPLOYEE
1Here's the beginning to the setup to 7.0.5.
1. In the software click the CONFIG button
2. Change the output option to SINGLE OUTPUT
3. Change your Sound Card option to ASIO
4. Change the dropedown menu to the right of your sound card selection to ASIO4ALL v2
5. Click Apply
6. Click ASIO config
7. Uncheck your your current sound card selection and choose the N4
8. Click the red X to close this window
9. Change your Outputs setting to HEADPHONES
10.Click Apply
| next » « previous |
can someone give me a link for 7.0.5b (b380) version of software?
- view 1 more comment
Jeff Hazar February 13, 2013 18:07this crack doesnt work. they caught on to the serial key cause EVERYONE is using the same key for the crack.EditDeleteRemove
acwh79 February 13, 2013 20:58SICK MAN!!! How can you come on here and start talking about cracks???EditDeleteRemove
I have a question, have the Nurmark N4 and want to change the skin like it can do??? Help plz
And the skin da i want it.... ( Mix Lad V3.1 )
but i need to play with 2decks :/
can u help??? tell me what can i do.
and i have my Nurma n4 2 Months.!!!-
pues vete a la carpera DUCUMENTOS/ VIRTUAL DJ/ SKIN.. Y LO PEGAS AII LA PIEL
I have VD 4.2 and thinking of buying N4. Does it work with the VD series 4? Our to also have to upgrade to VD pro? I like my 4.2 and don't want to change it If I don't have to
I bought a numark n4 but i can ́t use it with virtual dj version. who can help me please.
Thanks -
| next » « previous |
Loading Profile...
Twitter,
Facebook, or email.
