ns6 problem everything blinking / flashing
my numark ns6 has a problem
recently when i put out the power cord (from the power supply) and as i put it back in , everything starts to blink ( the blinking or flickering is fast and slow , it is not on a regular frequentie) and my pc doesn't recognize it anymore
1 person has
  • Hi Vincent,
    Thanks for posting. Sorry you're having issues with your NS6.
    Can you please confirm the specs of the power supply you're using with your controller? If you're in the US, you should be using a 12V DC 2A power supply.
    If this is the power supply you're using and you're still having issues with your controller, then it may need to be serviced.Warranty and non-warranty claims are not handled here on the forum, but I can point you in the right direction! Here are a couple of options that you could choose from:
    • Submit a Warranty or Service inquiry with our Technical Support team by logging onto the Numark Support Page. Select Warranty or Service Inquiry from the drop down menu.
    or
    • For quicker support, call your nearest Support Office or International Distributor.
    Make sure to reference or link this thread to help out the support team.
    I hope this helps! Let me know if you have any additional questions.
    e.g. happy, confident, thankful, excited kidding, amused, unsure, silly sad, anxious, confused, frustrated indifferent, undecided, unconcerned
