Platters on my NS6 become less responsive
I'm using Numark NS6 after 10 minutes or less my platters become less responsive, I cannot control tracks. I'm using OS X 10.11.4 and the driver for my Numark is 3.3.7 with Serato 1.6.1. Any suggestions?
1 person has
  • Hi Luis,
    Sorry you're having issues with your NS6.
    The platters on the NS6 are touch-capacitive, and static electricity can come into play with using these platters. If you're DJing in a highly-carpeted area or if your setup is not properly grounded, a symptom like this could occur. I recommend not to DJ on a carpet or a-highly carpeted area when you're using the NS6. Try using a surge protector and make sure that every plug that you're connecting to your surge protector is grounded (connectors have 3 prongs). Lastly, try the NS6 in a different room or with a different computer to see if you experience the same symptoms. Try this out then let me know how it goes.
    e.g. sad, anxious, confused, frustrated kidding, amused, unsure, silly indifferent, undecided, unconcerned happy, confident, thankful, excited
  • Hello Bill,
    I am not DJing in a carpeted area. I have followed the following instructions on the Serato website. https://support.serato.com/hc/en-us/a....
    I appreciate the quick response. I'll get back to you if I'm still experiencing these problems.
    thx,
    Luis
