This topic was archived on Thu, 13 Jun 2013 20:04:56 +0000
Archived because: .
LED Problems with Numark 4Trak and Traktor 2.5
I've got the 4Trak and it was working fine with Traktor Pro 2, although I had experienced problems with the Filter and FX LED's not lighting properly. I was quite relieved to see that other people had noticed the same thing. Incidentally, I solved this problem by setting up the 4Trak with the wizard, then setting up the preferences to detect the 4Trak. After I'd done this, I just exported the settings and now, every time I run Traktor, I import the settings and it works fine.
HOWEVER, I downloaded the 2.5 update and installed it but no matter what I do, the LED's on the FX/Filter's wont work.
Does anyone know the solution. I thought that maybe Numark would have updated the drivers for the 4Trak, but I don't think they have yet.
12 people have
this question
This topic is no longer open for comments or replies.
  • thought i was the only one. been really stressing on this for a while.
    but it feels good to know that there is some one out there with the same problem as mine.
    the good news is, i found the official tsi mapping file for 2.5, it was originally posted by petermunch on one of his youtube vids and i have posted the link on the bottom here.
    the FX and the filters works fine except the LEDs, sometimes it wont lit and sometimes its jes all crazy.
    but as per what u have mentioned above and how you got them working on Traktor pro 2, i believe u will be able to do that with this updated tsi file below.
    but i need your help to setup cause i am really new to traktor and all this mapping and stuff. so if u succeded with the updated tsi file, kindly let me know how.
    looking forward to hear from u.
    http://www.petermunch.com/wp-content/...
    e.g. sad, anxious, confused, frustrated indifferent, undecided, unconcerned happy, confident, thankful, excited kidding, amused, unsure, silly
  • is the sample deck mapping u mentioned above is for traktor pro 2.5?
  • We are looking into if we can improve the performance on our side. Sorry for the troubles. I will post as soon as I hear something.
    Amy, are you on windows 7 as well? Which bit?
  • all of you people are not alone..im still waiting a fix on this issue too..solved the x-fader contour slope..but this fx led's problem just wont quit on us... :( annoying fx led's if your in the heat of the mix...hope they solve this issues..or its going to be a choice between traktor 2( led's will work but no x-fader contour) or choice #2( traktor 2.5 fader contour will work but no led fx lights) what's your choice??? that is why im nailed to my ns6 and ns7..
  • I'm having issues getting the fx to work at all sometimes. randomly the fx bar will not work period and i have to disconnect and replug in usb to get it to work for maybe 20 mins and then it wont work again. Does anyone know why this is? I also had it cut out on me a couple times randomly when I was in the middle of a gig, made me look very amateur.
  • Same here. I try to remap in traktor but still not working.... Anybody fix this ??
  • 1
    Ok so here is solution:
    For now FX LED buttons dont work with Traktor version 2.5 (4trak edit or even PRO) - i dont know why.....
    But all work in version 2.1.2 and 2.1.3
    So @Camilo Vargas Yalo - x-fader contour/curve dont work in 4trak edition software because there is no such option in the program - which is very strange ...
    here is the screen of PRO version where is this option and it works as it should
    and now FX LED buttons
    First run setup wizard and select Numark 4trak:
    for now FX LED buttons should works , go to options > controller manager and change setting like this:
    and yes - should work on, but if you close the program and run again - it does not work anymore....
    all you need to do is change the in-port and out-port, 4TRAK-FX to "none" and back to 4TRAK-FX and it works.
    I have no idea why this have to do but most importantly it works.
    I hope the traktor version 2.5.1 now everything will be ok....
  • Can anybody tell me where to find the Sample deck 2by2 tsi, i can not get the loop recorder to record, before exporting it to sample slot, the video says i need this 2by2 tsi, i just cant find anywhere, their is only the reemix deck tsi, which does not see to do this sample recording, any help and direction appreciated.
  • Same problems here. The fx works and responds, except the lights on the fx buttons don't respond at all. I just bought the 4trak plus 2 kontrol f1s, so aren't interested in applying the sample decks tsi. I tried the "official 2.5 tsi" mentioned above from the peter munch link, but that only turned on some different fx lights randomly, still no on/off touch light response on the unit.
    The supposed fix with the fx in-port and out-port deselect and reselect doesn't work for me either.
    • view 1 more comment
    • cool, that works, thank you
    • Salut la solution temporaire est ; dans le controle manager mettre le FX a all port
      et a chaque fois que tu démarre Traktor tu sélectionne all port pour le main midi et reselection 4Trak midi
      Hi the temporary solution is; in the control manager put all Port for FX bar, and every time you start Traktor you select for main midi all port and reselect 4Trak main midi.
      please give me a star
  • Hi everyone,
    Is everyone here using a pc (windows) or some using mac?
    I' asking this because of this:
    Faisal Pasha 3 months ago
    Hi J Sandeen (Technical Representative)
    I have contacted Native Instruments regarding this LED matter and the respond is as follows:
    NI says:
    "the problem with the LED feedback for the 4Trak FX panel is a known bug in the
    driver of this device.
    We investigated this and the LED out messages get sent by Traktor, but ignored by
    the driver/device itself.
    Please contact Numark regarding this issue."
    So the problem is clear. they (native instrument) are aware of it but your(Numark) not. And they are asking us to contact Numark.
    The problem is not with how we installed it, the problem is with the driver numark has provided or the problem is in the device it self.
    So kindly look into this matter or if possible provide us with a link on which we can contact the person in concern because i dont know how get hold of them as they are no where to be found. Honestly speaking.. Numark has a very bad customer service and as a consumer i am very much disappointed since i bought this 4trak.
    And to take your confusions away: i have used the Traktor 4trak version that came along with the deck n which had the same issue then I purchased n upgraded to traktor pro 2.5 n still I am facing the same issue. And i am using a windows 7 64bit, 4GB RAM, intel duo 2 2.6GHz.
    So i guess that clears my end.
    So if it is the drivers of the 4Trak, is it the same for windows as for apple?
    I'd like to write something to Numark but for that I need to know this....
    Thx in advance
    Dominique
  • I really would like to know when this is going to be fixed. Visual thing or not.
    Or did we pay with visual money?
  • I’m Very pissed
    Is there somebody doing somthing about this at Numark?
    I really don't think so!
    Numark can solve this FX-bar issue if they put some recources in it. But that is clearly not as important.
    The customers who bought this product are idiots. We paid more money for this 4trak than for an S4.
    Everybody wants a sollution here! But at Numark their time goes into putting new products on the market.
    Catch the money and run ... How de we call people who do so?
  • 1
    I have been waiting for a driver update to fix the led issue. Thinking about selling the 4trak to get a pioneer
  • Hi Tony look up my comment made this it is the best before the update
  • The same issue. I've bought 4Trak 10 days ago. And my fx leds are not working properly. I have Windows x64, intel core i3 2.55GHz, 8gb ram...
    The fx panel works from time to time. Even if I change the settings from 4trak fx to none and back - no changes... Sometimes they begin to light if I restrat the Traktor or unplug usb cable.
    I think it's the driver problem. So all the people waiting for the fix, Numark...
  • Numark, please wake up.!
    The 4trak is an awsome controller, has a great feel to it, nice faders, goor size jogwheels, etc, etc.
    Now, please fix the issue with the fx-bar and the product is complete.
    If a hardware patch in the fx-bar is needed, please publish how to mod it.
    Tell me why this is such a problem. Traktor software sends out 1 or 0 (led on or led off). If the hardware on the fx-bar is not sensitive enough to pick up that singnal tell us where to put in some diode or change a resistor or whatever.
    If it is a fix that can be mede by changes into the diver, whell then fix it allready !!!
    BUT DO SOMETHING.
    A simple thing like that canot take 5 months.
  • Don't hold your breath! I'm putting my on craigslist today! I'm tired of waiting. Numark is forcing me to by the Pioneer DDJ-SX next week.
  • 1
    This is just getting ridiculous. I emailed Numark about 2 weeks ago to add my voice to this problem but I've heard nothing from them since. I'm not happy. As far as selling the 4Trak goes. 1)I do actually like the thing, if it wasn't for this problem. The build just seems far better than the NI S4. I like the design of the 4Trak.
    I'm just getting really frustrated because Numark don't seem to give a damn about the people who bought it. I never expected that it was going to be redundant after Native Instruments updated Traktor. I really want to use Traktor 2.5
    IS THIS TOO MUCH TO ASK???
  • Numark is not to be annoyed with a problem like this. They are way to busy to be even bothered with a futile thing like customer service!
    Why should they?? It is sold and the money is in the pocket.
    So it is clearly too much to ask!!
  • 4
    I used to do the port reassign workaround with Traktor Pro 2.1.3, but after an update to 2.6 nothing helped anymore. I tested around a little and found a workable solution. It will only work for Traktor Pro, I think, unless you can add MIDI devices in the 4Trak ed.
    Traktor 2.6 seems to work fine with the FX bar when it's set up as a generic MIDI device, instead of using the built-in 4Trak.FX mapping, which simply doesn't work. You lose no functionality, but the generic MIDI mapping won't have the friendly names for the controls available if you remap. Like this, the FX bar LEDs work great for me, no need to change ports every time.
    I replicated the built-in functionality of the FX bar in a generic MIDI .tsi, which can be found here. Add this as a new device in Controller Manager, set the in and out ports to 4Trak FX, and disconnect the ports from the built-in mapping.
  • reguarding the fx LED not working,many o you seem to have a work around,which seems to conflict with what i have ben told in my case.
    After doing some Troubleshooting with numark via screenshots etc, they have told me it looks like my unit Is faulty, so i have mine collected for so called repair today,
    But iam not so certain the Problem will get fixed as it seems more like Driver and software related issues to me, maybe some sort of firmware fix needed.
    when i first got my 4trak and set it up with the numark version of traktor included the leds worked, tested on both PC and laptop, soon after i installed the full version of traktor,the LED failed to work or was random in what LED light would stick on or off.
    so on my laptop i uninstalled the full version deleted all hidden files and registry, and installed the numark editing of traktor again, but this time my LED would not work, so something has happenned after i installed the full version of traktor, i dont know if any one else noticed this ?.
    anyhow i moved onto traktor 2.6 hoping this new tsi may solve the issue, but sadley not. I do hope it is fulaty and in my case it comes backed fixed, but i guess it probaly will not and the shop will tell me its fine on their setup, i have owned quite a lot of dj controllers etc, novation automap and their hardware drivers give me similar issue,it just seems that in this modern age of the computer their are always going to be some systems that such hardware works okay, others that do not, like i say my PC system is a good system, but i have no end of midi related issues, their is some underlying stuf that causes such conflicts.
    So all i can say in my case, if it works okay for them, and it gets sent back and does not work for me, i will not make do, they will have a fight on their hands, i will be demanding and chasing up my righst under the UK sales of goods act, where as it may be fit for purpose on their pC etc it is not on 2 of my setups, and this enough to conclude it is not fit for purpose on my Pc or as advertisted reguarding the included functions/features, and can in no way be related to being my fault, it is not us the consumers fault that these developers have not tested their products enough, and it is not our fualts that the hardware we buy in good faith becomes broken becuase of software updates as with traktor, this is all down to the other two parties and numarks communications with Native Instruments.
    so if in the uk you do have rights that will Prevail once all the detail is down on paper, it doew not matter if its only Led failing, it is adversised as this, so it must have this, also despite what the store and numark will tell you,your rights under the Uk sales of goods act if purchased in the UK and when asking for a refund or a exchange go way beyond the cuttof dates they may give, you have to know your rights, its all on principle. I hate having to go though all this, but if it aint 100% as advertised or keeps getting similar issues, you have many years to redeem your hard earned Cash if you can back up all your edvidence since day one, dont settle for being fobbed, just saying, if these problems persist anyone in the Uk has some of the best protection, so keep a record, take screenshots and video back it all up as you go, and doint give up, you wil win in the end, most of these companies know it can be a long process and many give up and give in, Be fare at your end, but sooner or later you can say no to compromise.
    Good luck to those that are still stuck with Broken LED etc, as with me i hope its solved very soon, it is a good controller on the whole, and with the new Features of Traktor 2.6 incorprated, it could be great, thrown in a F1 and its awsom.
    One last note,i dont know if this is the case for others or even if it is a user error on my part, but since 2.6 the Strip search no longer function and i cant find any info on this or any notice of change to control mapping in thsi area.
    all the best.
    • view 2 more comments
    • Hey Jason,
      I agree with you 100%. Numark doesn't give a damn about supporting their own devices once they cashed your money. Take the money and go.
      Why should we be left to workarounds and halfass fixes? Numark say they support X feature... if this is the case and something is broken then fix it! If you can't fix it, then do not sell the product in the first place as supporting this feature. Period. This is false advertisement.
      What a shame of Numark.
      Sincerely,
      Jules
    • I will appollogies though for the ranting iam reasonable, their just comes that time when you have to get stuff of your chest, for me its been coming for some time reguarding midi dj controllers etc, its just numark have bared the brunt, but vestax where probally even worse if i look back at it, but if in for repiar vestax did have a really quick turn around 2 repairs on my vci-400 jogs done in 3-4 weeks total,just slow with email support or aknowledgement in the first place.
      i Just hope, things work out for the better, numark where in touch with me within a couple of days twice in a row, i wasted a lot of my time watching this thread for answers, but the whole point, is not just about me, it was the fact that i read another post where numark said that if these issues had been reported they would have dealt with them, but this thread has been known to them for some time, so it seems a tag ignorant, and probally why i jump in thinking i want shot of this numark hardware, before i get stuck again, its quite clear they should have been on here asking questions more than i see has been, its their responsability to their hardworking paying customers.
      So thanks for the collab on this Jules,
      If only i had know about the poineer and the new serato software sooner i would have waited, i have never really been a traktor fan any anyhow, but it has the best sounding EQ and fx combos and fades/cuves on the controls etc, good for smooth mixing,so i had to go with it on that, but a nasty Over sized GUI kills it for laptops and poor beatgridding, amongs a few othr hates of mine, i took a chance hoping the intergration of this controller would make it more favourable, but as off yet i wait to fully start using it, the new mapping looks excellent but the proof is in the using, not judging from some manipulated overpracticed Advertising video, i feel sorry for some newbies thinking that what they see is that simple too do on the fly with traktor, been djing since 86, can mash the place,but Promo vids are a joke, one click here two click their etc, yeh right in the world of video editing and cheap visual gags, The best software for mix trick with loops and sample actually on the fly is serato itch etc, and mixvibes cross is the cheeky one it could be the best it is for looping and beatgridding 100%, but poor worthless effects and lame eq response and control fades/curves, make for clumsey mixes, its a dam shame, and som emidi communication/setup issues.
      Anyhow i wait with bated breath, and hope this/next time round i can eat some of my words, and i will, if that be.
  • Response from Customer Support Europe (Germany)
    Hello Mr. De Bondt,
    the fx-led problem is known in our home.
    The error occurs sporadically with the Traktor Pro version!
    The problem has also been given to our development. Please use the enclosed tuned to the 4 Trak "TRAKTOR 4TRAK Edition".
    Best Regards
    Sascha Michael Sandrock
    Technical Support
    Can you believe this? Go back to the "tuned" version! That is not only clipped but also misses much functionality.
    I am going to get my money back!
  • I’m confused
    Just bought my 4trak and i have the same problem...
    Using Traktor Pro 2.6 on Win 7 Home Premium 64-bit
    Toshiba Tecra Laptop
    The FX led's don't always work.
    Also i've had problems with some of the other led's not working to :(
    (Like the rings around the weels)
    Tried to install the 4trak edition from the disc next to my Traktor Pro 2.6, but that does not work... installation tells me a newer version is installed
    Is there a way to install the 4trak edition and keep my Traktor Pro 2.6 installed at the same time? (at least until this problem is solved)
    Thanks
  • The 4trak edition won't help there, since the 2.6 executables are exactly the same, a Pro licence just unlocks features in the program.
    For the main 4Trak LED statuses not updating on startup in TPro 2.6, try mapping a "Send monitor state" MIDI Out message somewhere and use it to make Traktor update all LEDs. I have mine mapped to both shift keys.
    For the FX bar LEDs, see the generic MIDI tsi workaround above.
  • It's strange, that Traktor sets the FX bar LEDs, when I plugin the 4Trak after starting Traktor, so they are in a correct state. After that, Traktor doesn't make any update on the FX bar LEDs.
    • Actually, if you Add it as a new device instead of using Import, your current mappings won't get overridden. Go to Controller Manager, Device section, Add button, Import menu option.
    • Ah, ok. Too late, because now I'm ready and it's running perfectly :D
    This is a solution for the moment if you don't change for general midi your FX bar
  • 1
    boumdj, this is not the best solution. The best solution is the tsi file from DJQA. Thanks a lot, DJQA!
  • I’m frustrated
    Does anybody here have their 4trak working properly at the moment? I have been attempting to resolve the fx bar lights issue to no avail after the recent traktor pro 2.6 update and 2.6 mapping. It is doing my head in completely. Whatever variation I try of mappings (the official 2.5 and 2.6 update, the DJQA one mentioned above / the sequence mentioned by marco that was deleted? etc) I get worse bugs, like zero function at all from the fx bar, and the loss of the loop buttons doing anything. The response buttons on the screen indicate that something is being pushed but nothing happens to the audio, let alone the lights on the unit.
    The "return to start of track button" has never worked for me with any software or mapping version.
    Right now it is a complete mess, constantly unpredictable. It's so random when it loads up, something different is always wrong. When I power on the unit random dials are not lit when they should be, and things like the scratch / jog button, the key knob and the tempo slider are way out of place on the software. I have to press every button a bunch of times to make sure it is either on or off like it should be and reset everything to where they should be starting. I used it once for a wedding, and the first song I played started horribly out of key, despite the lights on the unit not indicating the key was altered. Took me half a minute to figure out the problem and I felt awful.
    I'll have the latest 2.6 mapping installed as far as I am aware (with the key & close assignables are effects), then next time I restart the program it's changed and they're gone.
    I'm pulling my hair out just trying to get this thing to do the basics and I can't even practice, let alone use it for gigs which I am supposed to be doing soon, and fear I'll have to cancel.
    Every other controller unit I've worked with has been simple plug and play with no hassle, but I bought this 4trak and am learning traktor for the first time (the f1 sample capabilities swayed me as I can see myself using them a lot for messing around with transitions) and i have to say that while I can see there is potential with this set up to be a creative way to work, the lack of getting it all to run smoothly is beginning to make me resent it and hate it with a passion.
    Can somebody give me a clear walk through of what software version I should install and how for a trouble free experience if you have that, with what mapping, and what order to run the software / plug in the hardware each time etc.
    I have the 4trak and 2 Kontrol f1s (which I haven't even started to look at yet so disregard them for now), running on a new windows 7 laptop.HP probook 4740s.
    I just want to be able to DJ normally with it :(
    • Hi Nick, you mention a few performance issues that not many others are having so it seem to lean towards a hardware issue. If the controller keeps performing sporadically please call our warranty department. If you believe its a mapping issue, reload the map in the controller preferences.
      WORLD HEADQUARTERS
      United States
      Tel: 401.658.3131
      United Kingdom
      Tel: 0044 (0) 1252 896000
      Germany
      Tel: +49 2154-81299-20
  • Hi everybody. I tried all the tsi from Numark, even the new traktor 2.6 mapping - and no changes - the fx leds not worked... But DJQA showed me the only working way to make them working.
    I want to share tsi file (traktor mapping) for you. With this file I have no issues - fx leds are worked. All you need to do: Once the Traktor starts you need to go Settings - Import - And choose my TSI file.
    Also I changed some leds for main console. Looks great for me. All settings in this TSI are made by me for myself. So if you need you can easly change everything in Traktor settings. Maybe somebody will find something usefull in them...
    All changes I made:
    - grid move button: move grid of track to right (for some tracks which grids are not exactly falls into beat)
    - shift+ grid button: move grid of track to left (for some tracks which grids are not exactly falls into beat)
    - assign button of each deck: goes to 1\2 loop (could be usefull to use with effects or can be the effect itself)
    - Loop buttons: in-out-8loop-16loop-4loop, shift+these buttons: in-out-2-auto-1-32
    - View button: browser
    - Cruise button: Set master to masterclock
    - Left assign button of main console: set masterclock to 126 bpm
    - Center assign button of main console: set masterclock to 128 bpm
    Explanation of this setup: when I play and record my sets/mixes I press Cruise button and sync button of each deck. So all my deck are sync with mainclock. I don't must press sync for deck each time I load the new track. And all my set/mix has constant bpm. I press left assign button of main console when I play/record "slow" tracks, and right assign button of main console when I play/record "fast" tracks... Hope you understand me...
    - Right assign button of main console: quantize on
    - Left Key and right Key: FX3 and FX4 on
    - Left Assign Fader and Right Assign Fader: FX3 and FX4 wet\dry
    - Left Assing Knob and Right Assing Knob: FX3 and FX4 selection
    - Left KeyRing and Right KeyRing: FX 3 and FX4 parameter.
    The FX3 and FX4 I use for MacroFX so I set them parameters to 50 - when the effect doesn't make the changes...
    That's all... One issue I have with this TSI - fx leds start to work once the traktor running. But Main console leds (that I changed) don't work at once the traktor starts. Once the Traktor starts you need to go Settings - Import - And choose my TSI file.
    Good luck! And happy mixing! ;)
    Numark4TrakTSI
  • Anyone's 4trak freezing after a few minutes of mixing?
    I think we need high speed USB to fix all the issues but we can't use one cause of the fx panel! Anyway we can connect the 4trak with fx panel on two different usb ports instead of connecting the fx panel to the 4trak mixer? That way we can hook up high speed USB cables for both so performance and freezing won't happen?
  • Everything got fixed by re-installing drivers, and importing the latest 2.6 traktor mappings.
  • For me helps only to reassign the whole FX panel as a Generic MIDI device with cc commands not the FX bar commands. I'm working now on this to have full functionality for the new traktor 2.6 with post fader effects.
  • CAN SOMEONE PLEASE TELL ME,,,,,,,,,,,,,,,,,
    At present I'm using my 4Trak with Traktor pro 2.
    Is it possible to update Traktor 2.6 and have the FX Filter LED's working correctly???
    What do I have to do? Install the drivers and mapping files from the Numark site???
    Please can someone tell me (before I waste my time going through the hassle of updating Traktor then uninstalling 2.6 to get the 4Trak working again!!!)
  • I’m frustrated
    I can tell you ...
    It does Not work. You have to do many manipulations to get it working once.
    If you shut down and restart, again you have to do the same thing.
    Numark DOES NOT CARE for their customers. They don't even try to work out a solution.
  • Please see DJQA's response above which is: (his link to the generic midi .tsi file is included in his original post. This worked perfectly for me, and I have not had any issues with the FX LED lighting since.
    DJQA 3 months ago
  • I'm tryng to understand this step and I can't get it after many tries. After I imported I set it up but the effects or led light won't work. Can you helpplease DJQA.
  • After searching the internet for a couple hours this seems like the appropriate place to get my issues resolved. First my computer is running Windows 7, AMD A8 Vision, 16gb RAM and 620 HDD. I have downloaded the most recent versions of 4trak's Drivers from numark directly, and have also downloaded the most recent "Traktor 4trak edition" from numark as well.
    First my FX bar will not respond in any manner. I've tried holding the "FX MIX" and turning a knob to assign it and nothing happens. And when turning on the FXs directly in the console, with my mouse, there is no FX playback.
    Also my headphone jack and Main output seem to be on the same path, is there a way to change this, so that when I press the headphone button that track plays through them and the main track still going?
    • Hello J.Maillet,
      I have the following issue:
      In order to resolve the FX LED problem that has been ongoing since the 4Trak controller was released, I upgraded to Traktor version 2.6.1. However I did NOT purchase the Traktor Pro upgrade. It still shows that I am on the Numark 4Trak Edition 2 software package.
      Since upgrading, I have lost the ability to choose between different colored waveforms within the decks layout. I was able to do this when initially installing the software with my controller. Is there a quick fix for this, or will I need to upgrade to the Pro License?
    • Hi Nick,
      I believe that changing the waveform color is something that is only available in Traktor Pro. If it is included you would be able to find it here:
      Preferences>DECK LAYOUT>MISCELLANEOUS>COLOUR MODE>SPECTRUM
  • Hi All, please check out the latest Traktor mapping updates. It should help the Windows 7 users having the FX feedback issues.
    http://community.numark.com/numark/to...
  • i have this problem too. it usually goes away after i turn it off and turn it back on about 2 or 3 times. it hasnt really happened recently but i also never close traktor when i stop using it i just close my laptop and keep traktor open and when i connect the 4trak it works. however, i do have another problem sometimes deck d is quiter then a,b,and c, and it is like there is a filter on but there isnt and this problem wont go away but it only happens sometimes.
  • Hi Tyler,
    Try resetting the in and out ports in your controller manager, that will usually reconnect the controller for you. You can also save your mapping by naming it, if you open Traktor again and the map is not automatically connected you will just need to go into the settings and select the map you have previously saved.
    As for the deck D being quieter than all of the other channels, i have not heard of that happening before. Are the gain knobs in the software all set to the same level?
  • you can create perfect map traktor pro 2.6.1 for 4trak? FX led not run :(
    guys, some of you will know the 4trak even perfect mapping using traktor pro 2.6.1
    Someone may give the key and whether or create a mappeo for this controller, to make everything work properly?
    I will move my complaints and disagreement of this software to people of native instruments. can not create a specific program for a parent and resute that is updated as the software stops responding on the controller options.
    I refuse to allow this to be so and we provide solutions
    regards
  • Is there a solution coming for the Leds on the FX-bar?
    We are waiting for a half year now.
    And what do we see from Numark? Nothing at all!!!
    Every now and then J. Sandeen (Technical Representative) writes a line or 2 containing another not working solution.
    Native Instrument state loud and clear that it is a Numark hardware issue.
    What is wrong whit you guys at Numark? Lazy, incompetent or just not caring?
    What is the credo again? Get Satisfaction ??????
  • I played 2 little parties last week-end on the standard Traktor Pro 2.6.1 with no LED's on the FX-bar. All went smooth.
    Today at home I loaded the .tsi file : Numark 4TRAK Mapping for Traktor Pro 2.6.1
    Smile from ear to ear, finally the LEDs are working.
    But the smile was soon gone! 3 times Traktor crashed in about 2 hours time.
    And we are back to square one!!
    My config: Toshiba notebook with core i7, 4 MB RAM and Windows 7 (completely stripped), 4Trak and a logitech mouse.
    So now what??
  • Hi Tony,
    So the lights work but now you are experiencing crashes?
    What are you doing when the program crashes, did you get any kind of error message?
    When you load the .tsi map file be sure to do it twice in a row to make sure that traktor has installed it properly.
    In the meantime, be sure to go thru the guide to optimize your computer for dj performance.
    http://www.numark.com/static/dj-compu...
  • Wow.........ive been seriously considering moving from the s4 to the 4 trak.....after reading this thread......is this move a wise decision? Does the 4trak work now? Should I just wait for the next s4 replacement hardwear thats not been created yet?
  • Hi Craig,
    This has actually already been cleared up. You will need to make sure to have the latest version of Traktor Pro (at least 2.6.1) and import the new map we have provided. (When importing the map be sure to repeat the process twice to make sure it is installed properly)
