"I'm going to buy the Idj app for my Ipad, I was using MM on a PC and it was very good.
have you plan to add a function for pre cueing the song in headphones. I've made myself the adaptator and would like to use it for this app.
thanks" (via Beatmixing.com Forums)
Question From Madkite92 (via Beatmixing.com Forums) (Pre-cueing on headphones)
This topic is no longer open for comments or replies.
Official
Response
Hello, thanks for the suggestion we are considering adding this as a future update.
"Just bought the app!
The big drawback with the ipad is only one audio out. It would be great if you offered a queue option that used stereo bluetooth (to headphones or iphone), or airplay, or wifi (to a partner iphone app). This way I can still send stereo sound to the speakers for a live performance. Do this and you will RULE!
Id also like to load save files from Fusion on the PC to Ipad and vica versa.
Please display the Key of the song. And make it a search filter for tracks.
Finally, I have the Numark Mixmeister Fusion controller, if you could support that over usb via the photo/usb dongle that would be amazing." (via Beatmixing.com Forums)
This reply was created from a merged topic originally titled
From SpecialBlend (via Beatmixing.com forums) (IDJ App ideas). -
Loading Profile...
Twitter,
Facebook, or email.
EMPLOYEE
